I work in a very low configuration computer in my office. I try to store all the data in my pen drive so that i can work in my hope. I always do the same. So returning home today i tried several times to store my official data in my pen drive but i failed to store for an error. The error is
"ERROR_PATH_NOT_FOUND 3 (0x3)"
Now this making my really confused. I didn't face this problem before. I think this is virus problems. When I connect my pen drive into my pc I heard several times device connection sound which is very annoying because i got only single device connection sound before. Now give me ideas. its urgent.
Cannot store files in my pendrive
Hello Kelly,
The problem you have its a very common problem. people use get suffer by pen drive because of virus. As far I understood your home computer has very serious virus which destroy your file which was in your pendrive. Sometimes virus do this kind of things. You have to clean your computer.
First please scan your computer properly. then install a good anti virus software. than start scanning each and every drive. After clean all the virus make sure that your pen drive does not have any virus. please format your pendrive once. then again put the files into pendrive from your office. Then connect it with your home computer, scan it properly. If you found virus scan it properly and then you will your file is working now.
Thank You.
Your Pen Drive got infected with Virus. Have u installed Antivirus program to your PC . If not then download good antivirus software and run it. Also format your USB drive after scanning your system for virus.
