Cannot successfully uninstall Exchange 2010
What does this mean: “Uninstall cannot be continued” and “Mailbox Database 1375826892”? The mailbox database contains of arbitration, one or more mailboxes. I’m running my Exchange 2010 server that created an environment to Exchange 2003 servers. How could I completely uninstall Exchange 2010 and avoid errors during uninstallation?
Answered By 0 points N/A #103064
For both of the error messages that you have indicated in the question, I will suggest that you uninstall Exchange 2010 by going to your computer control panel and choosing add/remove programs, and when you have done that you will install Exchange 2010 again where you want.  But in the event that Exchange 2010 has already been installed, then that means that the schema/domain prep would have been done. So what you will need to do is to confirm with the other administrator if that is the case and also check your Exchangesetup.log and see if it shows that the schema has already been installed.
-Richard Gabriel
