Cannot uninstall Error tech software
I installed Error tech software and now I can't uninstall it.
I went to control panel to uninstall it. But then It doesn't show any software like that but the start bar shows.
Hello Myrna,
I myself have experienced this sort of problems before with other software. I am not very delicate with my computer so I simply delete all files and folder associated with the software (including program data file and any save files in c:users). But I will not recommend this and stress that you should probably forget I ever mentioned it. Instead you can download one of the following uninstaller and uninstall the software with them. I never tried them myself so check which one is perfect for you.
Revo Uninstaller , Your Uninstaller,SlimComputer, Advanced Uninstaller Pr, IObit Uninstaller.
Hope this solves your problem.
Notifications
