Daniel C.
Posted on - 09/04/2011
Hey fellows,
Strange program behavior on Windows XP. I've just installed a program called QPST.
This program I copied from my friend. This program is for setting a Mobile Phone Android Based.
Since it doesn't work at all, I decided to uninstall it, But I found it's nothing happen when I click "Change/Remove" button.
How to uninstall such program?
Does anybody here have been encountered such problem?
I'd like to hear from you.
Cannot uninstall QPST program from Windows XP
You can uninstall programs from Windows XP with a few ways. If one way is not working then try another one. When “Add or remove programs” panel is not working then try this.
Option 1
Click on our start button and go to all programs. Then find that program which you want to uninstall. Got into that program find uninstall option and click on it. Then follow the process.
Option 2
Find the installation directory where the programs or games are installed. Then find the uninstall icon in here and double click on it.
Option 3
Re-install the program and then try to uninstall again from “Add or remove programs”.
Or if all of the techniques that are mentioned above still did not work, then let us now try to use a third party program in uninstalling your software. Search the internet for McAfee QuickClean. I don’t know what version is the latest. This can remove any program regardless whether it has an uninstall file included or not. The programs that cannot be uninstalled from the Add/Remove Programs on Windows can be handled by this.
This program has the available tasks:
Start QuickClean Lite — will safely remove accumulated junk from your computer. It has the following cleaning options:
Recycle Bin Cleaner
Temporary Files Cleaner
Shortcut Cleaner
Lost File Fragment Cleaner
Registry Cleaner
Cache Cleaner
Cookie Cleaner
Browser History Cleaner
Outlook Express E-Mail Cleaner (deleted items)
Outlook Express E-Mail Cleaner (sent items)
MRU Cleaner
Search for unnecessary files to remove from my computer.
Remove a program from my computer — this is the option to remove the program that cannot be handled by the Add/Remove Program of Windows.
McAfee Shredder.
There are still other options that can be used for removing stubborn programs. Just explore the software.
Use any uninstalling software such as Perfect Uninstaller, IOBit Uninstaller, Tune Up utilities Uninstaller etc.
If you still face problem while uninstalling, then re-install the software.
Be sure that it has installed correctly. Then uninstall it. Just double click on the setup file without uninstalling and setup it.
Then uninstall it.
If you want, use perfect Uninstaller. It has "force uninstall" option for such tough programs which can't be uninstalled.
Use “force uninstall” to uninstall it.
It will be better and safer.
