I cannot uninstall daemon tools lite which shows active in my task manager menu. I have tried to uninstall it but it shows failure or to be specific the pc hangs when I try to uninstall it. It really is causing some CPU process and I need it to be Uninstalled soon since it goes not automatic start up on restart.
Kindly someone help me out of the problem.
Arnold Huang
Cannot uninstall tools for external file operation
If uninstalling an application in your computer creates a bad effect on the system like sudden freezing, hanging, or the system tends to become very slow, it is better to use a third-party application in removing stubborn programs like the one you have. Download Revo Uninstaller Pro at https://www.revouninstaller.com/ and then install it on your computer. Use this tool to uninstall your application. This program will analyze the application’s data and will remove it from the system and will clear your computer from any of its traces.
After removing the application, restart your computer. After booting, check your system for any possible errors. Use a disk utility application to check the system.
