Cannot update HP on my computer
When I chose the HP option in my start menu and try to update it, I get an error message. Can someone please help me with this?
Ok you all you can do is to visit the HP support center and try to see the option on how to update your hp. Or maybe you need to restart so that it will update all the files you have.
You can try one of the following solutions:
1. Try updating via HP site – Go to HP.COM.
2. You can download DriverBoost from here.
How to install DriverBoost?
1. First Download DriverBoost.
2. Click "Run" ("Save File" for Firefox).
3. Click "Run" Again.
4. Follow Simple Step-by-Step Instructions.
Notifications
