Anrei Tan
Posted on - 07/30/2019
I have a Logitech mouse that I wanted to use with my new PC. When I connect the mouse to the PC, it does not detect it and gives the error logilda dll missing. How am I supposed to solve this problem? I love this mouse and I want to continue using it.
Cannot Use Mouse Because Logilda Dll Error Logitech
Logitech is one of the biggest players in the computer peripherals industry. Logitech mice are the most popular computer mice in the world that are liked by professionals and power users alike. The error you are getting is a type of dll error and can be dealt with easily.
This error generally occurs due to the incompatibility of the Logitech software. The first thing you should try is to find out if the version you have needs an upgrade. If this is the case, upgrading the version should solve your problem. If this is not the case, then you need to download logilda.dll file from the internet and place it in your Systems folder. This should solve your problem and connect your mouse to the PC.
