Cannot verify that the Rescue Disk has been correctly burned.
Hi! All,
When I tried to burn the Rescue Disk I got an error message.
I am not sure about how to burn a Rescue Disk correctly?
Here is a picture to better describe my problem.
Cannot verify that the Rescue Disk has been correctly burned. If you have burned the Rescue Disk yet, please do so, and then click Next. If you attempted to verify a TrueCrypt Rescue Disk created before you started this wizard, please note that such Rescue Disk cannot be used, because it was created for a different master key. You need to burn the newly generated Rescue Disk.
Please give me some advice.
