Cannot view image in macromedia freehand after re-opening file
I cannot view image in Macromedia freehand after re-opening file.Several times tried.I cannot understand.What is the actual problem?
If this is the first time it happened on your application after opening a file again, try to restart your computer then try it again. If it still doesn’t work, try to do another clean installation of the program again to restore it to its default configuration and remove possible corrupted files in its installation. Uninstall Macromedia FreeHand from your machine then check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton Utilities, or PC Tools Performance Toolkit. Install the program again after this and check if this fixes the problem.
You may also try upgrading your current version of Macromedia FreeHand. Depending on the version that you have, the version of Macromedia FreeHand that I was able to find was Macromedia FreeHand MX 11.0.2. If your current version is older than this, then might as well consider upgrading to this version. Macromedia FreeHand MX 11.0.2 supports Windows 98, Windows 2000, and Windows XP. To download this version, you may visit Macromedia FreeHand MX.
