It is my first time to import some images to Macromedia Freehand and save it as a freehand file last night. Today, I have re-opened the file to continue my work but now I am clueless as to where my saved images are.
I assume that someone had accidentally deleted the saved images in the PC, since this is shared among our family or I have done something wrong in saving the file?Â
Can anybody help me on this issue?
Thank you.
Cannot view images in Macromedia Freehand after re-opening file
Hi!
Mostly we can find all the recent works we’ve done in the PC. If you are sure you have saved it, you still can locate it by the file name using the Search tool. Or you can check it on the Recent Items or in the Recently Changed Items on the All Programs Menu.
If ever the file was accidentally deleted depending on how your recycle bin is set for cleaning, it could still be recovered from the recycle bin, open your recycle bin; on the upper tab click restore all items and see if your files are back.
