Cannot work antivirus of my PC.
My computer was attacked by virus. I install avast anti virus.
But it does not work properly and cannot upgrade. My computer is working very slow.
I used a pen drive and virus addicted my computer.
Don't be upset, Sir. Its not a new thing. In this modern computerized world, virus is playing its vast role. So only you are not the victim. So to start with your problem, as your computer is already affected, if any of your friend has a hard disk cover i. e. USB plastic body cover which you can fit the internal HDD in it and can use it for external purpose too.
Now a days, viruses are getting stronger and stronger to keep pace with stronger antiviruses. You are also a victim of any strong virus that is preventing your Avast to become useless.
First of all, download and install Avast Virus Database Update. This will install the latest information about latest viruses and other malicious threats.
Start your computer in Safe Mode.
After your PC booted, run Avast. Scan your PC for viruses.
This should wipe out all viruses completely.
