Cannot write bytes in-div file using HUPlayer
I am having trouble using HUPlayer because I get the following error message when I try to open any file using this player the screen distorted and the error message gets appear. I cannot use this player normally. Is this problem with VGA or anything else? I have a enough config in my system to run this player properly. I want resolution to fix this issue. Please help me. Thanks in advance.
HUPlayer – Powered by Haihaisoft
Cannot write bytes in-div file.
