mithun
Posted on - 10/02/2011
I need a new printer and want one with the least expensive ink. I have seen ink cartridges in Tosco for 2 n 3 pound, suitable for some canon, and Epson printers. The trouble is i can’t find the printers that match the ink. How can I solve this problem?
Canon IP1700 Printers problem solution
TO: mithun
the problem of your printer ip1700.. i will give you some sulution
first…
They have cartridges filled with ink. Usually there is a door that opens. If the printer is plugged in it will slide the cartridge to the middle for easy access.
second
simple, just buy a cannon cartridge from a retail outlet oe authorized cannon store and follow instructions that is written on the back cover of each cannon cartridges…
Canon cartridges are very much expensive. Mainly we can use two types of cartridges in a printer.
a) Original cartridges.
b) Compatible cartridges.
Compatible cartridges are cheaper than original cartridge. By using compatible cartridge may damage your printer or will provide a low quality printing than the original cartridges.
For buying a new printer Epson is the cheapest. Epson provide 4 numbers of cartridges for black and color printing.
T1051-Black.
T1052-Cyan.
T1053-Magenta.
T1054-Yellow.
These cartridges are compatible in the following Epson printers:
T10,T11,T13,T20,T20E,T24,T30,T33,T40,T40W,TX100,TX101,TX102,TX103,TX105,TX110,TX111,TX112,TX113, TX115,TX121,TX200,TX220,TX2O3,TX209, C79,C90,C92,C110 ,CX3900,CX3905 ,CX4900 ,CX4905, CX5500 ,CX5501 ,CX5505,CX5510 ,CX5600 ,CX5900,CX6900F, CX7300,CX7310 ,CX8300 ,CX9300F.
