CANON LBP-6000 MONO LASER PRINTER driver not working.
I bought the Cannon best Printer few days ago it is in my daily used but move to outside of the city for business when I come back to home and start working some paper work then print it when I shocked that printer installed perfectly but it is not working and also after that printer driver differ to install in Windows 7.
Printer specification:
Type Printer > Mono Laser Printer
Printing Method > Laser Beam Printing
Print Speed > 18ppm
Mono: A4
Mono: Letter
19ppm
Printer Functions
Resolution > 600×600 optical dpi
Up to 2400dpi equivalent x 600 dpi
Fixing Method>On Demand Fixing
First Page Out Time > 7.8 secs
Printing Language > CAPT3.0
Warm up time > 10 sec or less (when the printer is turned on)
Recovery Time > approximate. 0.5 Sec
Media Handling
Paper Input > Standard: 150 Sheets
Max paper capacity: 150 sheets
Paper Size
A4/B5/A5/LGL/LTR/EXE/16K/COM10/Monarch/C5/DL/ISO-B5/ Custom sizes
Paper Weight > 60-163g/m2 (standard)
Paper Type > Plain paper
Heavy Paper
Transparency Label
Envelope
Consumables
Toner (Yield)
CART325: 700pgs (supplied)/1600 pgs (standard)
Monthly Duty Cycle > 5,000 pages
General Functions
Memory > Only buffers memory
Interface > USB 2.0
Operating Systems > Win 7/Vista/XP/2003/2008
Mac OSX 10.4.9 (Website download)
Power Consumption
910 W or less (maximum)
Approximate 295 W (operation)
1.6W (during standby)
Dimensions
359x249x198
Weight
5 kgs (excluding cartridge)
* In compliance with ISO/IEC 19752
Printer error file image in attachments.
Driver Software Error
Please help.
I am personally thanking.
Answered By 10 points N/A #83607
There is surely some error with the driver you have installed for this printer. May be some files are corrupt or misconfigured. Try to completely uninstall the installed driver and then restart your computer.
After restarting install the driver again and make sure no error occurs during the installation of the driver. Once installed correctly, I am sure the error will be gone.
This error can also be caused by an outdated driver. Try to install the latest driver for this printer. You can easily download the latest driver from the web site of CANON.
Hope this works well.
CANON lbp6000
Answered By 590495 points N/A #317274
If the printer is no longer working when you came back, try to uninstall and reinstall the driver. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select your Canon software among the applications and click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer. After booting, install the printer software back or download the driver again from the Canon website: Canon LBP6000 Drivers & Downloads.
The driver works only on 64-bit Microsoft Windows. Try also transferring the USB cable to another USB port.
