Canon MP150 Printer Not Feeding Paper with Error E23
Hi Experts,
I have a printer of canon MP150 model. But I am having a problem in feeding the paper on the printer. It is not taking the paper as well as showing an error like Error code E23. I tried it few times to solve. Now this is a big problem for me.
Tell me some ways to fix it easily.
Thanks and Regards
Answered By 0 points N/A #146804
Hi Joby Mathias,
I searched a solution for you it may help you solve your problem. Error code E23 means paper feed error.
1. Kindly check if the paper is properly loaded and if the rollers are functioning properly.
2. You may also try to turn off the machine and remove the power plug from the outlet.
Wait for about 10 minutes and try to plug it in again and turn the machine on.
