redkey25
Posted on - 06/11/2012
I recently bought a Canon MP287 Printer.
I installed the driver using the installation disk that came along with the package on my computer that has Core i7 8.0G RAM 64-bit Operating System using Windows 7 Ultimate.
I followed all the steps carefully everything else is working but the scanner.
Whenever I try to scan documents, the computer gives me an error message that it cannot launch MP Navigator EX 4.0.
By the way it works perfectly fine with my MacBook Pro.
I tried re installing the driver several times but I still get the same problem, it there a solution to this?
Canon MP287 Printer: Scanner is not working
Please follow the steps to rectify the issue:
– Try scanning from WIA. Go to start, type scanners on the search box and select view scanners and cameras. Check if you can scan from there.
If you can scan, the problem is the software. If you can’t scan, there is a problem on your computer.
If you can scan follow these steps:
– Use Revo Uninstaller to uninstall canon software. Download from this link: https://www.revouninstaller.com/revo_uninstaller_free_download.html
– After removing the canon software, download the latest software and driver for your MP287. Click on the link: http://support-sg.canon-asia.com/contents/SG/EN/0100290801.html
– Install the software
Check if you can scan.
If you can’t scan from scanners and camera follow these steps:
– Go to start, type cmd on the search box then right click cmd and run as administrator.
– On the black window, type SFC /scannow
– The system file checker will check the windows files and will automatically fix it.
– Try scanning again
If it won’t work, check your firewall if its blocking the port for scanning if it’s wirelessly connected.
Hope you will find this helpful.
Cheers.
Hello Redkey,
What you will need to do to resolve that issue is the following:
First, you will need to log off the account you are logged and then go back on to the administrator's account.
You will need to restart the computer and then start tapping F8 on the keyboard immediately.
A boot menu will come up where you will need to pick Safe mode with networking.
And then you will log into your account.
You should see a black desktop background as well as safe mode in all four corners of the screen to be sure that you're in safe mode.
After that you can try to open MP Navigator and see if it opens up.
Carl
If your Canon PIXMA MP287 printer has a problem with its scanner when using it on 64-bit Microsoft Windows 7 but it works perfectly well on OS X, try downloading an updated version of the MP Navigator EX driver. To download the latest version, go to MP Navigator EX and download the installer.
This is an updated version of the MP Navigator EX driver which was updated on July 22, 2015. It supports Windows XP Service Pack 2 or higher 32-bit only, Windows Vista, Windows 7, Windows 8, Windows 8.1, and Windows 10 both 32-bit and 64-bit. This updated version adds support for Windows 8, Windows 8.1, and Windows 10.
Also, it addresses the issue you are experiencing where the MP Navigator EX couldn’t start even if the application is installed. This should fix your problem. This version also addresses the issue when enlarging or reducing a copy where the result is outputted in normal size without getting enlarged or reduced in size.
