Canon Pixma iX6560 software resetter
Anybody here can provide me a software to which I will use in resetting the counter of Canon Prixima iX6560 printer.
Salvador.
Salvador.
Press the Resume/Cancel button and while holding it pressed the Power button to.
Then release the Resume button still holding the power button pressed.
Still holding the power button press Resume button two times in the row.
Release all the buttons.
Wait till the light is green and then press the Resume button four times.
There are different ways how to reset the ink counter. Try which method works on your printer. For the first method, press and hold one of the following buttons for five (5) seconds: Stop/Reset, OK, or Resume. After this, you will be able to continue printing under the “ink out” condition. If this doesn’t work, here’s the second method.
Press and hold the Resume and Power buttons simultaneously for five (5) seconds. After this, release the Resume button but continue holding the Power button. Now, press the Resume button five (5) times then release the Power button. You should see the blinking ink level/power light go steady after a few seconds. After this, you will be able to continue printing under the “ink out” condition.
If this doesn’t work, try the third method. Turn off the printer. Next, press and hold the Stop/Reset button while pressing the Power button then hold both buttons. Next, release the Stop/Reset button then press it twice and then release all buttons. Wait about thirty (30) seconds or until the LED shows without quotes “0”.
Now, press the Stop/Reset button four (4) times. After this, press the Power button twice. This should turn on the printer. Now, turn off the printer by pressing the Power button again. The printer should now be reset. Next, to reset the cartridge ink counter, make sure the printer is off then unplug the Power cable and the USB cable from the printer.
Next, open the cartridge door then press and hold the Power button. Plug the Power cable back while still holding the Power button. After this, close the cartridge door then release the Power button. The ink cartridge should now be reset.
