Canon Vixia HF G10 details
I want some details about Canon Vixia HF G10. Some technical details.
I want to know its Cam recorder sensor resolution, Digital zoom, Image processor, Lens type and its Internal storage.
Thank you in advance.
Product Highlights
The VIXIA HF G10 will let you record high definition videos for up to 12-hours with a less power consumption charge and shock resistant. The Canon HD CMOS Pro Image Sensor brings an excellent video resolution, with a fine low-light presentation and an advanced dynamic range. It utilizes lesser pixels with an effect of getting an enhanced video performance. It brings unequaled image quality.
Canon's DIGIC DV III Image Processor presents exquisitely sensible color and a classy noise reduction. You will find it remarkably realistic tone and information are captured by the 24Mbps recording at the utmost bit rate.
The Canon Vixia HF G10 is packed in every feature a video enthusiast could ask for. It’s an upgrade to the previous HF S21 and in contrast to the previous model has outstanding low light performance.
The Canon Vixia HF G10 has a great image feature. The HF-G10 has 32GB of flash drive, allowing for almost three hours of HD recording. When the internal memory is full, the camcorder automatically switches to its 2SDXC- compatible memory card slots which together can give you 12 hours of record time and super fast data transfer.
Recording Full HD 1920 x 1080 video, the VIXIA HF G10 features a Genuine Canon 10x HD Video Lens with an 8-blade iris for smooth background blur and dedicated manual focus ring for enhanced control. Perhaps the outstanding feature if the HF G10 is its HD CMOS Pro Sensor. The sensor is 1/3 inch, a size normally found in professional, not consumer level camcorders.
This larger size sensor captures substantially more light, providing gorgeous colors and remarkable image clarity.
The Canon Vixia HF G10 said to be The Optimus Prime of the Consumer. It is best for budget filmmakers and high-end enthusiasts. Here are some of the technical details that you’re interested in. First is the Camcorder sensor resolution which is 2.37 megapixels. The Digital zoom is 200 x, the Image processor is DIGIC DV III, the Lens type is 10 x x Zoom lens – 4.25 mm – 42.5 mm – F/1.8-2.8 and the Internal storage 32 GB Flash.Â
Here are some additional features of Canon Vixia HF G10 it has 24p Cinema Mode, a Built-in speaker, it can take photos while movie recording , Video snapshot mode and a lot more interesting features.
