Edzcloz
120 points
Posted on - 04/28/2011
HELP!!
Every time I visit the site youtube.com the whole site appearance turns white screen.
Can't access videos and even logging in my accounts. I've already checked my hardware and video card still the same, white screen.
Can anyone please help me solve this problem.
I miss watching YouTube since it was only my hubby.
Thanks
Can’t access YT white screen appears
I saw your post.
That's a big problem you got there. Same here I saw that error before in my PC. I guess YouTube already blocked your IP address.
You'll have to change your IP address in able to watch YouTube again +smiled+
Edzcloz
120 points
AW.
hey can I know how to change my ip address?
Edz ,
How to change IP address?
1. If you are using internet cable or router all you have to do is to restart your modem and unplug the power of the router/modem .
2. Wait for 5 minutes
3. Restart PC and plug your modem/router again
4. New IP again!
5. If your YouTube screen is still white repeat the steps over and over again.
Patience is a must +smiled+
– Next time do not use YouTube for spamming or any illegal acts that is why YouTube blocked your IP address and prevents it from entering their site.
:p
Edzcloz
120 points
Sorry I am using a wireless stick usb type connection here.
But anyways thanks for the help.
I wish I applied for a modem type of connection to change my ip.
mypchug
@edz
Hey guys try changing your IP address using VPNs for the meantime.
A program that can hide your current blocked IP addresses and replace it with other IPs out there., USA, Korea, China…etc..
Easy to use just run the program and follow the instructions.
IP addresses can be changed using hideips that is available all over the internet today
Easy Hide IP
Good for changing IP, hiding your IP and even protect you from spyware. Your YouTube problems will be solved after installing the program.
As usual, that is only good for 3 days….. As a trial version you must buy the full version to obtain the serial.
Another one
* YOU CAN ALWAYS CALL YOUR ISP PROVIDER, AND ASK FOR CHANGE IP ADDRESS I'm pretty sure they can help you with that .
Hoping you can watch the videos now
Cioa
Good job never thought of that!
I have one here realhideip but suddenly my ISP provider changed my IP address , no worries
Edz, Using VPN can slow down your computer use IPs that are nearest to your country example. USA., CALIFORNIA
In that way the connection will be stronger
Thanks
Edzcloz
120 points
Thank you so much guys for helping me out .
I'm already watching my YouTube videos right now.
I am using VPN and hide IP thank you so much experts!!!
