chris_wb
270 points
Posted on - 04/26/2011
Windows diagnosis shows that Network adapter driver has been crashed. Driver is Realtek RTL8139/810x Family Fast Ethernet NIC. I tried to update the driver and after that I am not able to connect to Internet from my Windows 7 Computer. Please Help. Thanks in advance.
apple
Can’t connect to net after driver update
Perform trouble shooting from the Windows action center and fix the issue. If it did not solve the issue, try updating the driver.
chris_wb
270 points
It didn't solve the issue. Will restoring the computer to a previous restore point, solve the issue? Can you please provide any alternative solution?
apple
Restoring will solve the issue. But the issue can be better solved in other ways. You can manually download the driver and install it.
Download Driver.
chris_wb
270 points
Thanks! How can I perform a Roll back? I am using Windows 7 ultimate. The issue is with Realtek RTL8139/810x Family Fast Ethernet NIC driver software.
master
Go to device manager.
Click on network adapters and select Realtek RTL8139/810x Family Fast Ethernet NIC.
Double click on Realtek RTL8139/810x Family Fast Ethernet NIC and go to Driver tab.
Click on Roll back driver and apply.
This will solve the issue.
chris_wb
270 points
Thanks a lot. It resolved the issue. I performed a Roll back and everything is working properly.
Trevor
Three ways to solve this issue, first is perform a system restore, perform driver roll back and download the driver from the manufacturer's website and install it manually.
System restore will restore all updates performed down to the restore point. System restores step by step procedure is available in this site. Just have a time for searching it.
Driver roll back will restore the previous driver installed for your hardware. Just open your hardware profile then double click the hardware and go to the drivers tab then click the driver roll back then apply.
Downloading the driver manually is your last resort. This is the best solution because whatever updates that your hardware manufacturer has, it might be included on the driver you are downloading. Just search your device on Google and look for the site of your hardware manufacturer on the search result then find the download on the site. Download the driver then install.
