How do you put pictures from, let’s say, the Internet to iTunes as an album artwork? I have an Apple Mac and I can’t copy-paste photos into the iTunes slot, like I would usually do using other computers.
bobii
Can’t copy-paste photos into the iTunes slot
There is an easy process, i am going to tell you now. Ready the pic format and then proceed.
First, you have to go to the browse view, select the album in your iTunes library, choose the file or press command-I for your mac. Then,click yes in order to edit information for multiple files and enable the artwork field by selecting its checkbox. click ok to make the changes. click yes to change the artwork.
These are the processes you have to perform.
Noel Sam
10 points
First open your browser then go to google.com, here you type your album image I mean which image you want. Next, choose your image and save on your computer. Go to iTunes and click on the song and go to the information page, choose album art and click on browse, choose fir the album and click on it. Next, it should be inside the blank box. Then click on the next song next there is our album art.
Or,
Open your iTunes
Here you choose Edit> Select All, Right click on select songs and choose Get Album Artwork.
After clicking on Get Album Artwork you see below picture and here you click on Get Album Get Artwork.
It will take some minutes to get all the covers.
After completing above process you see your cover page.
Thank You !!!
