Cant find audio plug in for Google chrome
I was trying to stream an audio asx file online. I use google chrome, and it isn't playing. I am searching for a plugin to fix this. Any way to do this?
If you want to stream an audio file (.asx) in Google Chrome using Ubuntu, You just need to download the Totem plugin to enable browsing and streaming online then try to update your Google Chrome to version 7 to make sure that the plugin will be compatible. That should do the trick.
First of all you should update Google Chrome if it is not and then follow the procedure below.Â
1. You just need to install Windows Media Player plug-in. For this please click https://windows-media-player-html5-extension-for-chrome.en.uptodown.com/windows
2. Click the download button on the above page.
3. Save the file and double click it to run and install.
4. Follow the setup wizard and restart Google Chrome.
It works.
