Cant get the libgcj implementation
Hi
Iam newbie to Java, iam unable to get the libgcj implementation of AWT/Swing/regex/threads/ etc under cygwin.
Thanks
Hi
Thanks
Hi Alonzo its a good thing you have asked that question, it has been experienced before. The problem may be that the implementation hasn't been done yet, or either the cygwin is not a supported platform by the java software
 If you are using win32, it may not be a supported platform for using the Mingw libraries, so the feature (if implemented at all) should work using the -mno-cygwin command-line option for gcc.
I hope this solves your query
Thanks
Please recheck the following:
>>Check if you set the implementations correctly in your Java.
>>Check whether the ‘Cygwin’ is a supported platform by the Java.
>>Windows 32 systems may not support the platform to use some libraries.
>>compiled applications are linked with GCJ runtime.
I hope the issue with the java application will be fixed.
Thanks and regards,
Skarbos Jay.
