Can’t install daemon tools on windows
Need a help guys,
I tried so many time to install daemon tools on Windows XP but i keep getting below error message:
Need a help guys,
Good day! Try to look for a different website for daemon tools and download it because there are some sites are corrupted. When you download it, try to install the daemon tools.. Here's the link for your needs http://www.download82.com/get/download/Windows/Daemon_Tools and click the MIRROR icon. And when it pop out just click "SAVE FILE" then you install.. If you done installing the daemon tool try to restart your computer and then click the daemon tool. I can guarantee you that this website is gonna work for your computer.. Enjoy the Daemon tool lite.
It’s a common problem in Microsoft windows. New software installation can damage this software that is already running. In order to solve this problem just follow this. It’s a very simple problem. Just go to msconfig and stop one service by doing these steps.
Now it will be possible to install this software. After install it enable those services that you closed.
