Cant install faceBook application on nokia 6300
I want to be connected FaceBook on my Nokia 6300 handset. That is why I have downloaded the application and tried to install. Then the application says “your phone is not configured properly”. I don’t understand the problem? So I need help with solution.
Answered By 0 points N/A #98984
Hi Paul,
Have you checked that your handset is supporting the application or not? Search the requirements for that application on the internet and read them carefully. Also read the method of installation. Maybe there is an error while installing the application. After that check the memory space of your mobile phone. Is it available for your Facebook application.
Secondly there might be an error with your application setup or your mobile phone settings. May be some kind of virus is there. So download the application from good sources and check the settings and memory card in your handset. Try to fix this or else you have to restore the factory settings to overcome the problem.
Hope that will be a good solution for you.
