Muneer
310 points
Posted on - 04/29/2011
Hello everyone,
I'm a new Mac user. Recently, I've purchased MacBook 2. 4GHz ,Intel Core 2 Duo, 2 GB DDR3 memory, 250 GB hard drive.
I want to install Office 2008 lIcensed Mac version, in my new MacBook. I already got Office 2008, Non licensed software in my Mac. I've removed the Non Licensed, Office 2008 from my Mac, (moved it to trash) and then tried to install the licensed version but it doesn't work.
Anyone help me to install my Office 2008 Licensed version in my new MacBook. I need the licensed version of Microsoft Office 2008 immediately.
Thanks,
Muneer
bappy
Can’t install Microsoft Office 2008 in My Macbook
Hi Muneer,
I'm using the same Apple MacBook with same configurations. At first when I purchased my Apple MacBook I also had faced exactly the same problem. Let me tell you how I recovered the problem.
It's very easy and simple. First thing what you have done wrong is, you just moved your Non licensed Office 2008 to trash. This is not the right procedure to uninstall your existing software. You have to delete it from Library.
Steps: –
Select Finder from your Dock then select Macintosh HD. You'll see a folder named Library.
Select Library, you'll see a folder named Application Support.
Select Application Support , you'll see the main folder which you want to uninstall from your mac permanently.
What you have to do, just move the folder into Trash. Select Trash from your Dock and Click EMPTY.
Your Non Licensed software of Microsoft Office 2008 is permanently deleted.
Now you can easily install your Licensed software in Your MacBook. Moving to Trash any software from your mac is not the only procedure to uninstall the software. You have to remove it permanently. Your problem was, you only selected the software from Application and then you Moved it to Trash. Doing this, your software is not permanently deleted, you have to follow the above mentioned instructions.
I told you it's very simple. Hope this will help you. Let me know whether you are able to install your licensed Office 2008, in your Mac or not.
Cheers
Bappy
Muneer
310 points
Fantastic, it's really simple and easy. I've followed your instructions and I am able to install my Licensed Office 2008, in my Mac and can use it without any error.
Thanks for the instructions, it really helped me lot.
Regards
Muneer
bappy
It's really good to hear from you that, you successfully have installed your Licensed Office software and can use it.
One thing I want to suggest is to, update your software regularly. It will help you to work in your software smoothly.
Thanks,
Bappy
Muneer
310 points
Thanks, for the suggestion.
Yes, you're right. I've to update my software regularly. At the end of my installation of Office 2008 Licensed software, I saw a dialog box appear in my Laptop screen. It showed, update your software Automatically or Manually, which I'll select for my software update.
Regards
Muneer
bappy
Dear Muneer,
Just select the Automatic option, this will help you to update your Software regularly. Automatic option will help you by giving you a notification whenever, there is a new update for your software.
Cheers
Bappy
sumya
HI Muneer,
It's very easy to install Licensed software of Office 2008 in your MacBook.
What you have to do is, delete your non licensed software from your Mac. To delete your Non licensed software permanently, you have to download App Cleaner software. This software is free. Just search for AppCleaner for mac in Google and then you will be able to download it easily.
After downloading you have to install it. Once it is installed, open it. You will see a box indicating down arrow which says, Drop Apps Here.
Just go to Finder; then go to Application, you can see a Folder named Microsoft Office 2008. Drag the whole folder and drop it in AppCleane software. Your Non licensed software will be totally deleted from your MacBook.
Now you can Install your Licensed Software for Office 2008 in your Mac.
Have a nice day.
Sumya
