Can’t install TrueView program properly
Hey there,
I have a very tricky problem. When I installed DWG TrueView, I the following error message appeared on my screen:
"Dwgviewr.exe is unable to start correctly. Error 0xc0150002"
Hey there,
I will try to guide you through this problem to a valid solution.
What we are dealing here with is a technical error caused by problems in the hexadecimal coding systems. This error specifically occurs when some DLLs are missing,corrupt, damaged or infected by virus. The problem can be anywhere that is in the setup file or the destination folder. So the following steps are advised:
1. Try to download a new setup file ,preferably a different version from a different source and not the one you used before.
2. Scan your system for virus problems by thoroughly scanning each drive.
3. Defragment your system before any of this which will make this process faster.
4. Restore your system to a previous point where it was known to work best using system tools.
5. Install the software and most chances are it will work without a problem.
Otherwise altogether you can search for a repair tool kit named after this error which will automatically repair the files. But do this only from a trusted source or you can compromise your system.
Hope this information was helpful,
Good luck.
