Can’t install Win7 64 bits on Vista
Hi all!
I failed to run the set up of Windows 7 64 bits. And an error emerged which reads -”Cannot install Windows 7 on this version of Vista.
Now I understood that it is because I’m using 32 bit OS. I need suggestions on ways to clean install.
Please also help me with the following issues: How to format C: on vista?
Is there any possibility for 7 to run at startup after formatted derives?
Help will be appreciated.
Answered By 0 points N/A #90519
You can only upgrade to a 64 bit windows 7 if you are using a 64 bit vista.
You need to upgrade your vista to 64 bit for you to successfully upgrade to windows 7 64bit.
You might also want to check if your processor is 64 bit capable.
Go to control panel > system & maintenance > performance & information tools.
Now go to view and print details.
You will see the 64 bit capable listing.
To format vista, go to control panel>system and maintenance > administrative tools > computer management.
Under storage in the navigation pane,go to disk management.
Right click on C then click format.
Hope this helps.
