Hi Guys, I am trying to open Twitter.app in Mac Operating system but when I try to open this error appears. Please if any one knows how can I open this app share with me. Thanks in advance.
All error detail is given below so that you can understand nature of the problem easily.Â
You can’t open the application Twitter.app because it is not supported on this type of Mac.
        OK
Can’t open the application Twitter.app
You need a different version of twitter for your Mac operating system. May be you are using a version that supported in Microsoft windows but not for Mac OS. There are many twitter versions in the market. Find a sweet able one that can be installed in Mac OS.
Another option is if you do not get it from market then you can find a version in websites that support Mac OS. You can search on Google for this. Here is a name of website https://itunes.apple.com/us/app/twitter/id333903271?mt=8 that has Mac OS supported twitter. Go to this link and download this version 2.1.1.
If that’s the error that means the Twitter app currently installed on your computer doesn’t support your current OS X version. This can normally happen when you upgraded your Mac operating system to a higher version. This is not a problem actually. You simply need to update the Twitter app. Click on the Apple menu and select “Software Update.”
Check if there is an available update for the installed Twitter app. Install all available updates for your computer. I’m not sure what OS X version is installed on your Mac but you can download the latest app on the Mac App Store: Twitter for Mac. The latest Twitter app supports OS X 10.10 Yosemite and higher.
