Mahimapu
Posted on - 08/04/2011
My laptop model is Dell studio-1458. Core i3, 3gb ram, 512 graphics card. But i couldn't play the game on my laptop. When i tried to play the game it shows texture is too large: 2048*2048, maximum supported size 1024*1024. Now what can i do to play the game?
asimm
Can’t play the game angry birds on my laptop
There might be a problem with your graphics settings. Check your graphic settings from control panel or by going to properties on desktop when you click the right click of mouse. Set the resolution according to the game and then try again. Or else you check that which windows you are using. Is it registered? And it supports the game "Angry birds" which you mentioned. Try to update the previous or the best thing is that uninstall it and download the new and latest version from a good source and make sure that your system supports the latest version. Other thing is that there might be some file corrupt or some virus is there which is resisting the running of your program so try to scan your computer and repair the windows and other files. Do this in normal mode or the best thing is to do it from safe mode.
Hope this will help you.
Almost everyone want s'Â play Angry birds ( one of that is me)Â game but the problem many of us faced is
“Texture is too large: 2048×2048, maximum supported size: 1024×1024″.
Now Here's the solution to get rid of this problem
First solution: Â Use this solution to get rid of this problem.
Go to Angry Birds installation path, and locate the config.lua file. Open with notepad.
Change the display resolution. Width =1024 and height = 600 (This is the supported resolution for Angry Birds).
Third: Save and close it, Run the game to see if the error message is fixed.
SECOND SOLUTION:
If the error message occurs again try this method check if your video card driver is installed.
Right click on My Computer then Device Manager, Click on Display adapters here you can see graphic driver.
If you don’t see graphic driver that means the video card driver is not installed in your PC/laptop.
Try these steps if you have your own computer hardware Video driver
Insert your graphics driver CD/DVD and install Graphics driver.
Now you will be able to play Angry birds.
