AlAdams
Posted on - 10/19/2011
I tried printing a dollar bill for a project when this message popped up, see screenshot below.
I clicked on the link displayed with the message, and it directed me to a website about counterfeiting.
Wow, even printer can detect the image I was printing! Anyhow, is there a workaround for this?
I need to print a dollar bill for my project.
Please help ASAP!
Action Not Supported
This application does not support the unauthorized processing of banknote images.
For more information, select the information button
below for internet-based information on restrictions for
copying and distributing banknote images or go to
www.rulesforuse.org.
lee hung
75 points
Cant print a dollar bill for my project
Hi AlAdam,
Can you try printing from a printer that is not connected to a network or internet (an offline printer). Because once you are online I suspect there is a software that tracks and monitors against printing of notes by unauthorized persons.
And it may not possibly add an exception to your case considering that yours is project work. Or you could opt to photocopy instead of printing, unless you have to submit your documents in a soft copy format.
But just try using an offline printer, and see if you can manage to overcome that problem.
Hope this helps.
___
Lee Hung.
Printing money is illegal but if you are printing a pretend money, it is not. As long as it is different size than the real thing, it is fine. If you are going to use it for your project, follow the following steps below:
You can visit http://freestuff4kids.net/ and select between the bills that are provided. After you click your selection, this will prompt you to open a PDF file containing three of the denomination you choose. Choose save to disk and make sure you know where you have saved the PDF file so you can access and print it.
Use your PDF reader to print pretend money as much as you want.
