Cant print from internet explorer 9
I can print from every program except internet explorer 9. How do I fix this? Adding words so this will go through.
The good thing is that since you are able to print from other programs so the driver of your printer is good and running and the problem is all about your internet explorer settings.
The first thing you need to check is the used printer, you can find it by pressing Alt key at your keyboard to show the menu bar then choose file –> print –> then make sure the used printer is the default one you are using with other programs.
Because some times its set to windows imaging and document scanning or to other pdf handling software.
Notifications
