Can’t Print Photoshop File in V. Card Size.
I've designed visiting cards for my company using Photoshop CS3 & now I'm setting Font Sizes. I've to take print outs again and again to check which font size looks appropriate on the V. card.
But I can only get a clear idea about the reasonable size, when I'm able to take Standard card Size Print outs. Right now, the print out size on A4 Paper is quite large from which, I'm unable to judge whether it is reasonable font size or not.
I want the print out size to be exactly the same size as of the visiting card size. Please tell me, how it can be done.
Answered By 0 points N/A #117773
Hi Dear,
You can do it very easy way. As per your post I think there is only resolution problem. So please follow below steps for increase the resolution and adjust actual print size.
Please open your Adobe Photoshop CS3 to Click Start Then All Programs.
Then Click File then open the file which you want to takes resize.
Now Click Image from Menu bar then under the Image menu clicks Image Size. Then new pop up will come. In the new pop up please uncheck Constrain Proportions as located in the Image below. Then Change with Document Size section.
