I wonder I am finding a hard time publishing my files online as the remote name is difficult to determine.
I need your help my friends. Find time to drop by and supply me with a solution to this problem.
Can’t publish files
The remote name could not be resolved:
‘picasaweb.google .com
Cant publish files through Blogger
Hello Dominic,
It is very possible to publish your files and even drawings and spreadsheets through a blogger. All you have to do is open the file or the item you want to publish then from the menu select publish to the web.Go ahead and press the start publishing button. On finishing to publish you will see a link to the published item. This link appears on the publishing dialog. You can now send this link to the people you would like to access your file.
