sally
Posted on - 09/13/2011
Hi everyone,
My computer is acting up again this time I get this really annoying pop up that I can't click away:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:Progra…
R6025
– pure virtual function call
I rarely use C+ and I’ve scanned my system several times for malicious software but the problem persists.
Can’t remove C++ pop up window
Hi Sally,Â
I'll give you the brief information about the Runtime Errors: The Causes of Runtime Errors and How to fix run time errors.
What is Runtime Errors?
Runtime Errors are the code libraries that loads by the application at the run time process. It seems runtime library becomes corrupted or unavailable to use that rely and are prone to crashing. There were many different runtime libraries available today. The most common libraries are the Visual c++ Run time library.
These libraries are used for a single application that runs in our computer. Because it is very important that these files will remain in good working that helps to maintain our computer in good and normal situations. Some authors of Malware often target these runtime libraries as they easily disable a lot of single application that cause killing the system libraries that my result runtime errors during working in your computer.
What causes a run time error?
A runtime errors simply describe as a problem that has a piece of code that cannot be loaded. You can see the several kinds of codes that Microsoft numerical code system found.
How to Easily FIX runtime Error?
Fortunately, there is a solution to fix of these runtime errors, you can download the following programs such as FixCleaner run Battery of troubleshooting diagnostic test on your computer. visit: https://slimware.com/ to download this software.
These is the Software application that will help you to fix during run time errors.
Hope this will help you a lot. Happy programming.
TracyArjay
Good day,
For simplicity we can assume that both launching and launched applications have single "stack" of windows (one main window with modal dialogs that can have own modal dialogs).
Jacksonn Maria
