tisha2011
Posted on - 08/11/2011
Hello there, I use idm 6. The resume option sometimes does not appear. Sometimes it doesn't even show the download in the list. What do i do if a resume capable download was stopped by sudden electricity outage or whatever? After restarting the pc it doesn't appear on the list. Help please. I use Windows Xp sp3. Thanks in advance.
Can’t Resume Download on IDM
You just thought it out. Relocate the particular .part record to the download listing as well as rename this to .jc! and also restart this making use of flash get.
Resume the obtain that was cut off during an electric outage result in it leads to the particular file to be corrupted….rather redownload the actual document or obtain a downloader program which will save this for you personally and obtain the file when you've got time and energy to try downloading the file….only in the event you stop the particular download wouldn't it be safe to obtain the actual document again….. Furthermore what kind of Web connection do you have ??? Dial up ?? DSL ?? Cable?? Fiber?? How big is the file though and where you downloading it the actual record coming from will probably also figure out how fast it gets saved also as well as some time and bandwidth has to be taken into thinking about when installing large file(s).
1. Open the file in the browser which you want to resume, click it to download it again. When the dialogue window will appear select it to download it later.
2. Double click on the file that you have choose to download later.
3. Copy the URL (ctrl+c):
4. Now, double click the file which has not been resuming since and paste the address that you have just copied there and then press ok.
5. Now click on the concerned file in IDM and click on resume.
Hence your problem has been solved.
You can check this article for more help.
