Cant update my Corsair Force GT 120 GB SSD
Hello
I am using the Corsair Force GT 120 GB SSD with Firmware 1.2 on my system. It is working perfectly fine as before installing it I set BIOS to AHCL. The flash utility was also running as admin. It was successfully installed but before I reinstalled it an error appeared. I successfully downloaded FW from a website and installed all window updates and drivers. The drive was connected to native SATA3 port controlled by AMD southbridge.
Now just yesterday I purchased another Corsair Force GT 120 GB SSD but with a new firmware of 1.3.3 which was already installed with it. So now my target was to update my old SSD FW from 1.2 to 1.3.3.
When I tried to do so I was met with an error. The screenshot of the error is as follows:
FATAL_ERROR: Firmware download failed with error :(ECode 0000000057)
OK
I don’t know why this happened but I think it might be due to the difference in FW.
Your suggestions are required to fix the issue.
Waiting for your response
Regards
