Youtube Videos run so slowly
I used Windows XP (service pack 2) before. Recently,  started using Windows 7. Everything was ok but when I watched something in YouTube via internet using Firefox browser,  I encountered same problems with all the videos:  YouTube videos run so slowly . I am not talking about buffering problem. I installed adobe flash player (latest) also.
I didn't encounter this problem when I used (windows XP service pack 2) . Now what can I do to solve this problem?
Best Answer by gigarose
Answered By 0 points N/A #87077
Usually, Firefox got Profile Corruption Problem.  Sometimes, one or more files of the installed extensions are damaged.  Some of the settings in the configuration are changed and were not reset during reinstallation.
  1. I suggest before installing new extension, back up first  your profile.
  2. Copy data to the new profile.
Answered By 0 points N/A #87079
Hi!
I suggest you  reinstall the Firefox applications because maybe there was a file that has been corrupted during the installation. So, before you reinstall that application, back up first your files.  After you install, reset/refresh the installation process.
Hope it will solve your problem.
