CAPI WORKER Module Error on start up
When I log into my system I get an error "CAPI_WORKER Module has encountered a problem and needs to close. We are sorry for the inconvenience".
What should I do?
What should I do?
The error capi_worker module error is found in Sony Ericsson pc suite. This is usually due epmworker.exe failed to start i.e unable to locate component which is usually a missing file ShowMfcDialog.dll. A good suggestion is to re-install the program or upgrade to a newer version as this problem might come again.
Hi there,
Hello Alex,
Your set is Sony Ericsson and you are using Sony Ericsson PC suite. Am I right?
If yes, then you need to uninstall any software or drivers came with your Sony Ericsson phone. After this, reboot and reinstall them. After rebooting and reinstalling them, you can connect your phone.
Hope this will help your problem.
Have a good day.
Paul Jolie.
Notifications
