Captcha Sniper – Cannot find ‘captcha.gft’
Hi Experts,
The problem is with my Virtual Private Server (VPS). I received an error message while installing it. It indicates that it cannot find some file in required directory. I have no idea for the image issue. Have you any idea for the issue?
Please help.
Cannot find ‘captcha.gft’ located in C:PROGRA~1CaptchaSnipercaptchastype1
Captcha Sniper
Answered By 0 points N/A #191150
Installing virtual private network server needs internet connection and local network should be configured go to start button select admin tools then search for routing and remote access then press name of server in list and select configure, enable access in the action link then choose VPN in the common configurations window then select next and make sure TCP ip be in list and proceed with instructions in Microsoft site support section search for VPN installation guide.
Hope these shall helps you.
