Capture flash presentation website are downloaded
Does Flash Video Capture software download flash presentation website clips and store them in a recommended location like any other download manager would do or how does it work incase you want to use the clips for future viewing?
Answered By 0 points N/A #166932
Hello.
It can perform all the task that you've mentioned above. However for this you need to download the 3rd party software, Then you'll able to download the flash content and can save it, At the desired place. Now i am giving couple of links, Go through all the details of the product and take a action according to that.
http://www.multidmedia.com/software/zinc/
http://www.multidmedia.com/support/livedocs/zinc/4.0/
There are few trial version of the software is also available, You can check all the features of the software and in depth review  as well.
Thanks,
