Capture flash presentation website by download managers.
TechyV,
TechyV,
It can perform all the task that you've mentioned above with many other features. However for this you need to download the 3rd party software, Then you'll able to download the flash content and can save it, At the desired place. Now I am giving couple of links, Go through all the details of the product and take an action according to that.
http://www.multidmedia.com/software/zinc/
http://www.multidmedia.com/support/livedocs/zinc/4.0/
Hi Wales,
When I was developing flash applications, I am also curious on flash animations, flash websites and other flash object that I’ve seen on the internet while I am browsing. So I decided to search for a software that can view action scripts and elements, and can download the .swf and .fla file.
Then I found a very complex tool. So think SWF Decompiler can do it all for you. I’ve been using this software for over a year now, and it works like a charm. I can now review best flash slide shows and websites then try to apply it on my own works.
You can download Sothink SWF Decompiler on their website and you can start free trial now.
I hope it helps.
