I'm searching for a freeware system to capture streaming video freeware record streaming motion picture. I have a program(and there are a large number) that can record any sound that is played on my machine, is there something similar to that for movie?Â
jumiduss
Capture streaming video freeware program
If I understand the question correctly, you are looking for a video capture software to record videos that you play on your computer. I would suggest looking at FRAPS. It records things like games, youtube videos,ect. basically anything with frames per second it will pick up. Unfortunately, there are no free programs that work well, I have looked, so try the free trial of FRAPS before buying it. I'm happy with that program, it runs light and isn't that complex. Hope this helped.
Link to FRAPS:
http://www.fraps.com/
maxic9
I guess, I know what you are looking for.
I am using Web Stream Recorder program for recording the streaming video. Take a look at their short video tutorial and I think you'll understand if that is a solution or not. However, this program is not free, but I found a great similar software location service, just pick the free solution here:Â
https://sourceforge.net/projects/streamrecnet/
