Print Screen the whole page of the site
I wonder does anybody here ever have some difficulties to capture entire web page into a picture.
What I mean is a whole page from top to bottom.
I tried to use the print screen function, but it only captures the entire screen not the entire page.
The page needs to be scroll down, but how I can do two tasks together — capturing and scroll down the page.
Does this possible?
Best Answer by kimanif
Answered By 0 points N/A #120132
hello there
it is possible to take the whole web page as a picture, but not by using printscreen option
just simply do following steps
If you are using Internet Explore just install an addon called fireshot you can download.
if you are  using Firefox Browser search for the  " Fireshot Addon for firefox " it will lead you for the page  or you can download it from the link
install the  firefox addon
now go to the web site you want to capture
after you load the web site you can just click on the save button which appear on the right side of the status bar in the Firefox browser  it will be same as in the Internet Explore from this addon you save entire webpage without any problem.
Thanks
Answered By 0 points N/A #120133
If you want to make a snapshot of a scrolling window, a menu, or just a part of the screen, you need something more powerful than the Windows XP Print Screen functionality.
SnagItis an excellent tool for that. It's not free, but you can download a 30 day free trial from techsmiths website you can do a lot using the snagItis like capturing buttons, menu's icons, windows, any part of any window or application, scrolling windows, logo's
SnagIt beats the Windows XP Print Screen functionality on this task.
You can even add short video clips of onscreen activity or text callouts to illustrate the steps you want the reader to follow. You can convert any number of images to a single file format and add effects such as borders, watermarks and drop shadows all at one time.
Answered By 0 points N/A #120134
I searched for a thread like this.
Thank you very much, Kimanif  for giving such a helpful tool.
Thanks
