Capturing high resolution images on Mac screen
Asked By 190 points N/A Posted on -
I recently bought a Mac PC that am still learning how to use it. I want to capture web cam high resolution screen images but i don't know where to change the resolution settings. I would like to be guided in use of mac screen capturing of high resolution images.
Best Answer by Goram Ian
Answered By 60 points N/A #163484
Hi Heather Carr,
I have read your concern and made a brief research. It is best that you would tackle this with other Mac OS user. I have attached some links of forums below for your reference.
Mac World Forums: High Resolution Screen Capture
I have also attached a Link of Mac Hints.
Mac World Hints
Hope that it helps you a lot with your concern.
Answered By 0 points N/A #163485
You have to
Double click the hard drive icon to open then click "Application" folder to open it. Then click "Utilities" folder and double click "grab" to open it. Then select "Screen" from the "Capture" menu to capture the screenshot of the whole screen.
At last click "File" and select” Save" to save the screenshot.
Thanks
