HELLO !
I need to backup my whole MAC as I bought it 3 days before. It is not a brand new MAC , slightly used by its previous user but it is a new version as compared to old one. Now I want to clone my older MAC to this MAC , can I use carbon copy clone for this ? And is carbon copy Cloner automatic ? Means I do not want to do manually anything.
Is carbon copy cloner automatic ???
Hello Deangellopeter,
Carbon Copy Cloner for MAC allows you to make a Bootable clone of your Mac OS. It helps you clone your entire OS as well as synchronies specific files/folders using the incremental backup. You can even schedule your Backup. You can even backup to a network share. Yes Carbon Copy Cloner is fully automatic just create a schedule for backup and the rest is taken care by CCC.
Hope this helps.
Thanks!
