Carbonite backup mirror image error
I'm using Carbonite for my backup and I tried their Mirror Image Recovery but Carbonite is giving me this error, I'm just curious on how this feature will work, any Carbonite user there who also experience this?
Mirror Image Error
Carbonite was unable to make your Mirror Image drive bootable. You can still use Mirror Image for full snapshot
backups. However, you will need to use a recovery CD if you want to restore your computer with Mirror Image.
Learn how to create a recovery CD.
Close window
Answered By 0 points N/A #147563
If you see the error message, you need to run boot tool that will help you to retrieve your image before restoring through mirror image. Yet your image will be saved in your external drive. Then you need an additional step if you want to restore your image. Just click OK to continue.
Carbonite will start to create a mirror of your PC and to save it to your external drive after your drive has been formatted and prepared. The process may take several hours which will depend on the amount of space being used by your system and may slow down your system at the time of the initial mirror image. When you see the initial mirror has been completed, everything should be alright.
Hope it helps.
Hathy
