Card reader driver for Mac
Hello guys,
I am using MacBook pro. I cannot copy files with my USB compact flash card reader. The LED lights up but I couldn’t copy anything. I think it is a problem of card reader driver for mac. Is there any suggestion? Can anybody help me?
Answered By 0 points N/A #138499
Good day Mr. Randy Baler,
Yes i think there's a problem with your card reader driver.
Here are some of the suggestions that might help you:
1. Try to double check your card reader driver.
2. Try to insert your flash card reader on the side of your MacBook Pro.
3. Locate your Media Reader icon on your desktop. And try to open the files or contents of your flash card.
If you cant see the contents of flash card, try to insert your flash card reader to other computer and see if it works.
If its your card reader is really the problem, check you MacBook Pro box and there's a disk in there for bootcamp or manual, check it if there are any solution about reinstalling the driver, or bring it back to your Apple store to check it or fix it.
