Card Reader for iPad available in Ebay
I have seen a SD Card reader in eBay that can be plug directly to an iPad so I download the pictures in the card. Does this really work? Does Apple really have something like this? Any ideas?
 What eBay give is depend on giver. Firstly you check item and their condition.
This is true that Apple made that type of card reader. With this iPod sd card reader you can easily download photo or video.
With this type of card reader you can download and upload data also.
With this card reader iphone 3G will not work and not supported.
When you connect this card reader to your iPod, automatically show their content in iPod. You want to transfer or copy your selected content or data.
hi
Yeah ,ipad now supports Card reader which reads SD cards and some CF cards also.Its available in market and you should check the product is not fake .Now its most common to find a card reader adapter for ipad.Using a card reader you could directly download the files to a card.Actually Apple is not releasing the product but ,many other products like MIC that have a USB pin to connect with ipad.It take a very little time to transfer files.But you couldn't view videos from card directly.Hope you could buy the product and hence use it for downloading pictures.
Triclers frost
