Card reader support in USB 3.0
10 points
Posted on - 02/06/2015
I have a card reader that is meant for internal connection in a desktop, when i plug it into the motherboard I get a message that the high speed device should be connected to the right port for USB 3.0. How can I know if a machine has 3.0 support and is there like a PCI usb that comes with 3.0 support?Â
